URGENT! How to disable car OTHER THAN disconnecting battery or pulling fuse?
Old Apr 25, 2021 | 06:52 PM
HondaMom76's Avatar
Default URGENT! How to disable car OTHER THAN disconnecting battery or pulling fuse?
Usual ways of disabling are ok unless your alcoholic husband knows this trick because you tried to save his life once or twice. .Any other ways of disabling my car that will go unnoticed by a someone that will check the battery and fuses? He wont check past that...maybe disconnect a connector or something going to ignition or fuel pump?. He is planning on driving my 99 Honda Civic to work tomorrow morning knowing its not getting coolant to the engine! He just blew his truck engine 2 wks ago because it was out of oil. My car was stalling and having electrical issues. Had the Honda place put a new ignition switch which fixed the stalling but not the fan. He drove it like that for the last week even after I told him I smelled antifreeze.Turns out its spewing antifreeze out of the resevoir now and water coming out exhaust pupe. I know. I know. Head gasket but it still starts and its not sitting on the road dead yet.
Old Apr 25, 2021 | 07:03 PM
Aradin's Avatar
Premium Member
Default Re: URGENT! How to disable car OTHER THAN disconnecting battery or pulling fuse?
Swap a couple of spark plug wires around.
Old Apr 26, 2021 | 03:06 AM
Taylor Woollen's Avatar
That's a pretty good one. I'd say take a picture so you know where to put them back to, but plug wires seems like a good prospect.
Old Apr 26, 2021 | 06:59 AM
99stockcivic's Avatar
Put a potato in the tailpipe
It will start but then it will stall.
Old Apr 26, 2021 | 08:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
How about unplugging the engine harness where it meets the chassis harness on the driver's side between the shock tower and the firewall... near the clutch master cylinder reservoir. Separate the plug partially without fully parting the two pieces of the plug so it "appears" to be plugged in... this severs power to many components on the engine and it will not start. The check engine light will come on after multiple starting attempts.
XZeroBandit
Oct 21, 2019 05:37 PM
350crazy
Aug 13, 2010 03:10 AM
rSol93
13
Dec 28, 2008 07:30 PM
ITRbroham
Nov 4, 2004 06:30 AM
jbt75rsx
Feb 5, 2004 06:24 AM
