K Swap a 1994 Honda Civic
Can you K swap a 94 Civic Coupe and how easy would it be? I realize anything can be done but is it worth it? I’m new to cars not so new to JDM my first car was a 97 Honda Accord that got stolen. 😭 At that point though I knew nothing about engines, swapping etc. at this point I’m familiar with most motors from B series to K. My knowledge is all book and forum and no practical. I have a chance to get a 94 civic coupe for $500 it has D15B7 which I know can be a good tuner motor but I like the new tech and a K20A2 is what I’m looking to buy and swap. If there’s already a forum for this please direct me. 🙂
Thank you for all the background on who you are and why you want a K20.
Here is a useful guide to doing a K swap on a '94 Civic coupe:
How to K swap a 94 civic coupe
k20a.org
Hybrid-Racing has a full guide you should acquire as well off their site.
I would not advise doing this swap if you don't have at least a moderate amount of comfort/experience doing this type of work.
Ima newbie and this’ll probably be my first swap I know I picked a hard one but I have a friend who does LS swaps if that’s any constellation… he seems confident. Is there an alternative? I want 200-250WHP daily driver that’s reliable and K series is amazing.
Also I’d like to add I’d like to avoid a turbo and prefer superchargers. If I could get 250WHP with just a k20A2 new headers, pistons, etc. I’m cool with that.
Might want to just pay a local tuner shop to do the swap. You’ll save yourself the hassle. K swapping a ‘94 is nothing like a B series swap. It requires cutting into where an old engine mount goes and replacing it with a new engine mount.
if you want to get 250whp, you can do it with an all motor B series and it would be much more simple.
Thanks for the info and I actually have an update on this I ended up buying a 97 Honda Civic with a mostly stock 1.6 B series motor in it I’m not sure what the model is yet. He just told me it was a B that’s bout it. Idk if that’s enough liters to push 250WHP without blowing it up lol. I pick it up next weekend after he raise it back to stock height. Rn it’s on ksport adjustable coilover with a camber kit.
Look up build threads from people who have done B20VTEC builds, or read some of the "All Motor/Naturally Aspirated" subforum, it's a very common build.
250WHP will be out of the ballpark but a properly built B20VTEC can do 220-230WHP all day with no complaints. Paired with a short ratio transmission like an ITR or B16 trans, it'll rip.
If you're willing to give up air conditioning you could also look into the Kraftwerks supercharger kits for these cars. They work well and produce more HP than an N/A setup, but require removal of air con.
Build a B20 short block on the side with high compression pistons and forged rods. Save up for some cams and valvetrain on the B16 head that you already have, and when you're ready use your existing B16 head on the B20 block you just built.
Ok… so I have some bad news. The civic that I ended up paying for… The day I tried to pick it up the guy gave me my money back. The went on to tell me he sold the car to a buyer who offered more. So now I’m in a whole different scenario and I feel bad cause you guys have me awesome advice! But.. I’m going to have to abandon or delete this thread not sure how that works and start a new one. Tomorrow I’m buying a 1989 with a 1996 JDM 1.6L Engine (Same Size Motor 🤣
Non Vtec Honda CRX for 3 grand it’s worth 5g’s (body, functionality, and parts). After a long search and a lot of dead ends I’m getting the car I wanted in the beginning. I’ll be starting a new thread or look at current threads for builds for 200WHP-250WHP if possible. I understand that that’s a lot to ask from a 1.6L. Also idk what series it is just know it’s JDM
It looks good so far. Do you still want about 250hp? If so, the easiest way to obtain it would be a turbo kit, and would probably require removing the A/C unless you get an A/C compatible kit. You could probably make 250hp on stock engine internals if the tune is good and it’s in good condition, but it would be near the limit of what’s safe for a D series.
I’m not sure what you mean by “pro-charge”. There are turbocharger which hook into the exhaust, super chargers which connect to the intake manifold, and all motor which means there are no power adders. All motor usually means upgraded high compression pistons, camshaft, intake manifold, header, valvetrain, etc.
200 horsepower is obtainable on either of these routes. With turbo, you might not be able to keep the air conditioner though, depending on the kit.
You have a D series engine, and the way to identify which type it is, the engine code is stamped on the front left side of the engine block, to the left of the exhaust manifold.
Osek_818
Jun 10, 2015 02:08 AM
