Power steering pulley reomoval tool
Old Apr 24, 2021 | 12:08 AM
hawks85's Avatar
Default Power steering pulley reomoval tool
Does anybody know if there is a power steering pulley removal tool for 99 Honda Civics ? I got the nut off but that damn pulley is stuck on there. I seen some removal kits but I dont think they work with Honda's. The kits I've seen have a tool where you stick something in the shaft of the P/S pump. My pump doesnt have a hole in the shaft it's solid and threaded.
Old Apr 24, 2021 | 11:22 AM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Power steering pulley reomoval tool
A two or three jaw pulley puller works just fine... you may want to use a socket over the end of the P/S shaft (but would fit inside the pulley opening as the pulley begins to come off) since you don't have an index hole in the middle of it. The pulley is splined, so it may just be a bit "grumpy" coming off.
dsturch1
Sep 28, 2009 04:28 AM
ys1civicsi
Feb 9, 2007 11:26 AM
GreenMachineRex
Sep 17, 2005 06:08 PM
EL-Driver
Aug 3, 2003 07:27 PM
