Honda CR-V & Element 2WD & 4WD Element & CR-V
Normal MAF air flow rate at idle?
Old Apr 22, 2021 | 09:37 AM
christsizeshoes's Avatar
Default Normal MAF air flow rate at idle?
Can anyone comment on normal MAF air flow rate at idle, especially for 3rd gen (2007-2011) CR-V? Also please mention if you live at high elevation as that would change the expected value.
I'm seeing 1.6-2.1 g/s at 650 rpm near sea level. Suspect this may be too low and a sign of a bad sensor, which would help explain some other issues I'm having.
Old Apr 22, 2021 | 10:21 AM
Ryanthegreat1's Avatar
Default Re: Normal MAF air flow rate at idle?
Roughly the same g/s as the displacement. A 2.0 liter would be roughly 2.0 g/s at idle. I would say you are roughly in the ballpark.
EGRhatch
May 20, 2020 07:23 PM
Ritter57
May 25, 2008 10:01 AM
JRG151
Dec 11, 2007 11:58 PM
CRXalwysk8
12
Jun 1, 2005 01:07 PM
LShatchie
Apr 3, 2005 04:40 PM
