No More Rasp, No More Farts, Drone Is Nearly Gone! The Solution.
https://www.summitracing.com/parts/jex-a4540s
Any hint or suggestion of rasp or fartiness is completely gone. Warm idle is near stock quiet. Cruising above 2K is completely tame. Acceleration has a bity of deepness, but most of the noise is in the mid and high frequencies, from the intake and engine.
Yes, it's a louvered glasspack, but when using a larger size than stock, you're not likely to lose any significant power. I'm using 2.5" mandrel bent piping from the header with a large Dynomax Super Turbo muffler at the end, and the car pulls to redline the same as with 2x perforated core resonators I used to have. They did little to get rid of rasp and farts, and were almost useless at removing drone. At this point, I can make a quarter wave resonator, get rid of the narrow band of frequencies causing the last of the drone between 1.5K to 2K, and enjoy a quiet yet free flowing exhaust at any RPM.
Here are the other sizes available:
https://www.summitracing.com/search/...eversible%3ano
Remember that the longer the glasspack is, the quieter things will be. I picked the longest one (45") and it 100% KO'd the frequencies I needed it to (rasp between 2.5K and 35.K and freeway drone) and more! And yes, at 4" round, it has no problem fitting under the car.
I did a set up like this with no muffler on a 1996 Saturn SC2.
30moons.Com - Reviews of the Saturn Aftermarket
In case anyone wants to read about quarter wave resonators and muffling:
https://core.ac.uk/download/pdf/328816729.pdf
Is there a formula for how long the glasspack must be for a car to produce the sound you want? In other words, is it based on airflow? Or horsepower? Length of exhaust?
Something else, about drone in general, is that there's a TON of tuning done for stock exhausts to eliminate it, beyond just piping size, type of bends, and what kind of silencers are used. Materials, weight, thickness, overall length, positioning of bends and silencers, etc. all contribute to reducing drone. Done poorly, all you're going to be doing is fighting against your own creation. I think adding the mass of the glasspack, plus adding a second spherical/ball joint after the glasspack (to aim it properly; I don't have a welder :/ ), have doubled down on reducing drone by reducing exhaust system vibration. Both by adding mass, and by splitting the exhaust into 2 separate parts, instead of it being a one piece tuning fork.
As far as glasspack sizing, I've read many reports about how an 18" resonator or two will cure rasp, but mine (from a Yonaka exhaust) didn't silence it. A big improvement from a straight pipe, but still ricey. I might try something half the size sooner or later, just to restore the stock ground clearance (I'm using universal clamp on hangers around the glasspack; again, no welder :\ ).
BlueBomberTurbo
Jul 22, 2020 01:31 PM
garados
Jan 27, 2007 11:01 AM
X2BOARD
Jan 15, 2004 08:45 AM
