Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2006 Accord door trigger wire
Old Apr 19, 2021 | 02:53 PM
aliok's Avatar
Default 2006 Accord door trigger wire
HI
Installing shock sensor for my Honda, need to connect Blue wire to driver side trigger wire, anybody knows which wire is that ? or how to find the door trigger wire
Thank you
Old Apr 19, 2021 | 06:34 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 2006 Accord door trigger wire
If you're looking for the driver's door trigger, it is a green wire that runs from the driver door switch to the under-dash fuse box; at Connector E at the back of the fuse box, terminal no. 15 (green wire).
Old Apr 20, 2021 | 02:38 PM
aliok's Avatar
tech8 Thx a lot for replying
Great diagram, before I check your reply I followed the wires what come from the door to the upper side of the fuse box and connected with 2 x light green plugged to compartment, I found 3 different green wires, * Light green, green with silver ring, and green,* I checked these three wires, connected the blue wire of shock sensor to green with silver or gray ring, and shock-sensor worked, checked several times all ok but today it does not work, making me crazy
let me check your info and back to you again
by the way, I opened the door cover and car door and windows switch panel what located at the driver door (same panel which there are some buttons and key to open and close door and windows) also some wires what come from door hook, no green wire goes out from the switch into the car, I took some photos
thxx
Old Apr 20, 2021 | 03:45 PM
aliok's Avatar
Here is the plug but no pin 15 green
Thx
Old Apr 20, 2021 | 04:47 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
There is no photo.
Old Apr 20, 2021 | 05:49 PM
aliok's Avatar
Sorry , I'm stupid the diagram says back of fuse box , was hard to access , anyway I found that , but shock sensor does not work , I do not know why car security does not react to the pulse of shock senso , I gave up , I do not know what to do more 😢😢
Thank you
Old Apr 20, 2021 | 07:16 PM
aliok's Avatar
Here is the photos
kcjohnnyboy
Audio / Security / Video
27
May 10, 2008 08:30 AM
SHG_Mike
Jun 24, 2007 11:52 AM
99hondaaccord
Mar 19, 2007 08:39 PM
low_crx87
Oct 8, 2005 12:58 PM
