Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Rear windows dont work
Old Apr 18, 2021 | 11:54 AM
twotonecivic1's Avatar
Default Rear windows dont work
Just checked the fuses for the rear windows and they are not the problem. Could it be that both window motors went? They havent worked the whole time i have had the car so I dont have any more info. Any ideas will help thanks guys!
Old Apr 18, 2021 | 04:25 PM
benchwarmer's Avatar
5 Year Member
Default Re: Rear windows dont work
Make sure they aren't locked out at the main control .
Old Apr 19, 2021 | 10:33 AM
NDNV's Avatar
Then check that there are no pinched wires in the driver's front door hinge conduit. Common issue and I have been through it twice. Wires get brittle and flexed many times and will break. Then likely culprit are the window regulators - been through one already - did this repair myself. Then check the switches and wiring.
Old Apr 19, 2021 | 03:10 PM
Thanks for the info. Very helpful going to go through all the things you brought up! just need to grab a volt meter and to see if i still have power going to them. Thanks again!
ITR #1202
Honda S2000
18
May 26, 2010 04:09 PM
zero708970
Dec 19, 2008 06:20 PM
UgP
Jun 16, 2007 10:51 AM
b20acura
Jun 25, 2006 12:45 PM
Dan GSR
Sep 17, 2002 11:35 PM
