Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
06 Odyssey Engine mount bracket to block
Old Apr 17, 2021 | 10:09 PM
Legacyautomodz's Avatar
Icon5 06 Odyssey Engine mount bracket to block
Ok. I'm looking for 2 bolts... I have a 2006 Honda Odyssey SW 3.5L V6
5FNRL38736B094077
The engine was leaning when I bought this project.. so I examined and found a busted engine mount, the support that goes around it was busted, and the bolts that go down into that support on its side that mounts to the block behind the timing cover had the 2 bolts broken into it... Extracting them is not an option. Therefore I ordered the engine mount #50820-SJMHJ-A03 and the support that grips around it #50620-SHJ-A00 which whose 2 bolts on its engine side was broken into this other support mount piece that i ordered #11910-RCA-A00 that goes into the block... I need the 2 bolts that go into the middle support and down into the mount piece on the block. I added the labels of Part #1, #2, and #3 for the pictures of them.
#2 bolts to where my thumb is. These are the 2 bolts I need.
#3 bolts to where my thumb is. These are the 2 bolts I need.
#2 links to where my thumb is.
Old Apr 17, 2021 | 10:35 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 06 Odyssey Engine mount bracket to block
Online Honda dealer sites show the related bolts:
https://www.hondapartsnow.com/parts-...ne_mounts.html
Old Apr 17, 2021 | 11:45 PM
OMG i Love you you awesome human being !!!!!!!!
Old Apr 18, 2021 | 12:05 AM
What about the bolts for the part that those bolts go into... the part on the engine block. i see those 2 vertical ones that i was looking for and thanks, but there are 4 horizontally input bolts also: 3 that are about the same size with 2 side by side (that I need) and i have a good one for the 3rd one right underneath them, but also need the smaller horizontal one at the very bottom. This diagram doesnt show that side of things.
Old Apr 18, 2021 | 07:50 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
1. Engine side mounting bracket,11910-RDJ-A00:
  • Bolt, Flange (10X85) - Honda Part No.: 95801-10085-08
  • Bolt, Flange (10X120) - Honda Part No.: 95801-10120-08
https://www.hondapartsnow.com/parts-...k_oil_pan.html
2. Engine Side Mount,50820-SHJ-A03:
  • Bolt, Flange (12X110) - Honda Part No.: 95701-12110-08
  • Bolt, Flange (12X20) - Honda Part No.: 95701-12020-08
  • Bolt, Flange (12X65) -Honda Part No.: 95701-12065-08
3.Engine Side Mounting Bracket,50620-SHJ-A00:
  • Bolt, Flange (10X40) - Honda Part No.: 90164-SHJ-A00
Old Apr 18, 2021 | 12:19 PM
Is this #29 the one that goes horizontally and on the bottom left side... down directly under the top left bolt?
and Is #30 the 2 bolts that goes horizontally on that side that are both side by side?
Old Apr 18, 2021 | 12:47 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
The one bottom bolt is BOLT, FLANGE (10X85).
The two upper bolts are BOLT, FLANGE (10X120).
See images.
Old Apr 19, 2021 | 12:20 AM
Thanks. I started on the job tonight and got the upper timing covers off but the support mount still wont slide out...wrestled with it for an hour and gave it rest until tomorrow. I removed the tensionner & pulley, upper 2 timing covers, and all bolts of the lower cover that I could reach from surrounding the crankshaft pulley, including the one that goes through the bottom of this part. But it kept getting caught into the timing cover gasket but any idea what it may be on why its completely loose and moving but won't slide out?
DIABOLIC8
Mid-Atlantic (Sales)
Aug 4, 2009 11:19 AM
lsvtek
Sep 29, 2008 11:45 PM
TurboLaxx
19
Feb 20, 2006 11:37 PM
