2011 EX-L Coupe foglamps
Apologies in advance if this has been discussed. I tried searching and didn't find my particular issue.
I've recently come into possession of an '11 coupe. I want to install factory foglamps. Is the 8th gen post-facelift coupe pre-wired for these lamps or do I need to completely run the wiring?
That said, am I better off installing the stock or aftermarket stock replacements or just go for the aftermarket?
I'm more interested in amber/selective yellow lamps over white.
TIA.
TIA.
The car's harness has connectors for an OEM fog light kit. But, it still need the fog light harnesses that are part of the OEM fog light kit.
https://www.collegehillshonda.com/in.../foglights.pdf
OEM or aftermarket is your choice.
Laminate film (such as Lamin-X, others) can be applied over clear lenses to change colors if you don't get yellow lenses.
Curated Content Editor
Honda-Tech News
Oct 26, 2020 02:32 PM
