Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Walmart vacuum oil change??
Old Apr 17, 2021 | 10:58 AM
Snoravon's Avatar
Default Walmart vacuum oil change??
So I had my oil changed at Walmart I didn't know till after but they use a vacuum to suck the oil out if I had known that I wouldn't have had them do it. Now my engine has a slit tock like the valves need adjusted or something. What should I do could it be walmarts fault? The car is a 04 civic ex and has 197,675 on it.
Old Apr 20, 2021 | 05:41 AM
aw614's Avatar
10 Year Member
Loved
Default Re: Walmart vacuum oil change??
I've used an oil extractor on my brother's 02 and mom's 04 Civic and have not encountered any issues with ticking.
Did you check the valve lash?
Old Apr 20, 2021 | 05:58 AM
NDNV's Avatar
Check the oil level and what type and viscosity oil did they put in it?
Old Apr 20, 2021 | 09:43 AM
Snoravon's Avatar
It was over a quart to full . I was told the valves just needed adjusted. But yesterday someone slammed into it while it was parked in my driveway and now it can't be driven anyways. Bad week.
Old Apr 25, 2021 | 12:50 PM
benchwarmer's Avatar
5 Year Member
Blessing in disguise ? Those ninnys may have started the car with no oil in it or something , and even in court you may have lost . A quart full would maybe throw a bearing , I think . A ticking noise is not a good sign .
azi90
Jul 31, 2013 12:34 PM
garyc17
Dec 24, 2008 08:02 PM
tilhasbb
Honda Civic (2006 - 2015)
24
May 28, 2007 12:11 PM
Paprika
24
Sep 11, 2006 04:38 PM
return_2020
11
Jan 5, 2005 05:42 AM
