OBD 1 Issues
Old Apr 15, 2021 | 12:42 PM
William2574's Avatar
Default OBD 1 Issues
I’ve been trying to read codes constantly but still have no luck. While trying to jump the 2 pin connector it doesn’t flash anything and it’s almost like it doesn’t register it. I don’t know if it’s supposed to have 12v but I connected a multimeter and got around 4-4.5v. Any help is appreciated as I’ve been in limp mode for awhile now.
also curious as to what the 2 and 3 pin connectors are attached to. Is it apart of the main harness or it’s own thing? I’ve tried seeing about getting a new one but can’t find anything anywhere to buy it
Old Apr 16, 2021 | 04:31 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: OBD 1 Issues
When you short the two pin connector on the passenger side kick panel, does the engine light come one solid?
Old Apr 16, 2021 | 04:42 AM
Yes it just stays solid.
Old Apr 16, 2021 | 09:51 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
That means there are no codes stored. You should check your 7.5amp back up fuse in the under hood fuse box. Make sure it's a good fuse. This fuse if burned out will constantly reset the ECU.
slimster
Aug 28, 2017 05:15 AM
JimmyM86
Honda Civic (2001 - 2005)
Jan 8, 2008 01:45 PM
lledcomp
Apr 24, 2007 11:09 AM
