Front Fender Rust Repairable ?
Old Apr 12, 2021 | 09:59 AM
CvicGng's Avatar
Default Front Fender Rust Repairable ?
Recently just checkout the underbody of my civic and saw this monstrosity growing. Was wondering what could I do to fix this rust ?
Metal was also soft to the touch fyi.
Driver Side Under Front fender
Old Apr 12, 2021 | 10:48 AM
danteisme's Avatar
Loved
Community Favorite
Default Re: Front Fender Rust Repairable ?
I had teh same issue on my integra, one side was worse than the other. You'll want to take off the wheel and fender to get a good look at what you are working with. My bad side was so bad that i had to cut out rusted metal and put in new metal. The other side was taken care of with a flap disc and i sanded all of the rust off i could get to. After i made sure the metal was solid, i cleaned it up and coated it with POR 15 or chassis saver, i forget which.
Old Apr 13, 2021 | 02:15 PM
CvicGng's Avatar
Im dealing with the same situation and do you think it’s possible if I could see some pics of your final result to compare mines to? Also how did you get the rust off from inside since I seen there were holes on both sides. Thanks for the reply back didn’t think any1 would respond much appreciated
Old Apr 13, 2021 | 09:30 PM
Zypher's Avatar
If your not gonna take the parts off, or can't, for cleaning then I've got a heck of a tip.
Ryobi makes a battery operated 18 volt rotory tool that is freaking great for getting wire brushes into very hard to reach places. Is basically just a very thin wand with a Dremel style Chuck on the end powered via cable from the main unit.
Any Dremel accessory works with em.
About 80$ depending on sales.
I would recommend that with a bunch of different shape/style wire brush heads. And wear a mask, rust dust is nasty.
You might need some kind of rust solvent for the deeper stuff, but works great for surface stuff.
Old Apr 14, 2021 | 04:17 AM
danteisme's Avatar
Loved
Community Favorite
Sure i'll grab some pics. That part of the car spot welded to the front chassis of the car. So unless you want to drill a bunch of spot welds and the re-weld the piece back on, your options are limited as to what you can do from the outside. For mine, i sprayed Eastwoods internal frame coating to the inside of that portion of the car (and others too). It comes with a long flexible hose with a tip that will spray in4 directions i believe. Pretty sure Eastwoods has a video showing how the product works. After that was cured, i used topped it with some 3m cavity wax for extra protection.
ADAMnQuickRDX
47
Nov 7, 2015 11:46 PM
zsiya
Sep 30, 2013 10:21 PM
low_and_slow
Paint and Body
Mar 25, 2010 07:39 PM
RineRacing
Oct 30, 2001 06:52 AM
