Anybody have a picture of a OEM front strut mount for 92-95 civic ???
Does anybody have a picture of a OEM front strut mount for a 92-95 civic I’m putting together a set of koni yellow/ground control and bought these kyb strut mounts but if you notice the rubber isolator underneath has circles notched out to sit flush against the two bolt heads inside the mount and I’m supposed to swap the rubber isolators with the provided ground control ones on the left that are smooth and don’t sit completely flush against the mount so I wanted to know if Honda’s OEM mounts have the same two bolt heads that stick out thanks!!
