97 prelude mt in 96 accord axle problem
Old Apr 8, 2021 | 04:10 PM
Eugene Carter's Avatar
Default 97 prelude mt in 96 accord axle problem
So I put 97 prelude tranny in my 96 accord. Everything went well. Just having problems with drivers side axle.
The small part was already attached to the tranny. I removed it to put the axle in and my axle is as u can see is different then that. I dont know much about it
Old Apr 9, 2021 | 03:32 PM
99stockcivic's Avatar
Default Re: 97 prelude mt in 96 accord axle problem
I've heard of people doing this, although I had heard you could use a Prelude on the passengers side, you had to use an Accord axle on the drivers side. Multiple reasons, I thought the length was wrong and the input shaft was also wrong.
So, I have no answer except "yep" that doesn't fit.
If I can ask, why not just use the accord axle?
Old Apr 9, 2021 | 04:43 PM
the hole that axle goes into the tranny is bigger then the accord axle. And if I have that little piece that fits in tranny on it then the axle be to long
Old Apr 9, 2021 | 06:06 PM
Looks like then you have to take the end off the prelude and put it on the accord axle.
Also, do you have to change the hubs also? Or do they fit fine on that end?
If that doesn't work to swap the ends, then you have to cut the axle to length so it fits.
Old Apr 9, 2021 | 06:11 PM
Here's someone who did it and explains all the options. Hope this helps:
https://www.preludepower.com/threads...to-get.288172/
Old Apr 10, 2021 | 01:50 PM
So does is prelude half shaft shorter then accord? Or is the diameter bigger where it goes in to the transmission.
anyways thank you everyone for the replies. I just have to get prelude half shaft then.
pali
Jan 6, 2019 07:22 PM
accordmatt
Mar 1, 2011 03:45 PM
1JDMCB7
Nov 9, 2010 12:15 PM
distruggo
May 14, 2008 02:36 PM
EuroR 5th Gen
May 7, 2007 05:36 AM
