this is my 3 wire iacv from a 2004 Accord 2.4L. when i connect it to my Megasquirt 3x ECU and dial the coolant temperature up and down using a JimStim simulator, shouldn't I see the rotor controlling the opening between the left and middle cavity move smoothly to open or close the connection between the two? is there a way to bench test this valve?
Are you having idle issues?
I'm not familiar with your EMS but with Kpro the IACV can be deleted with a few adjustments. This is what i did on my K20A2 because mine took a dump and wouldn't work as good.
