1998 AWD Rear differential repair
The drive shaft was already gone when I bought the vehicle. I had a mechanic check out the rear diff and he said it’s very loose and has a lot of play to both sides which is probably why the drive shaft was removed. I’m asking is that bearing issue or some other part I can replace or should I just replace the entire thing?
mackul1
Honda CR-V & Element
Jul 17, 2019 03:14 AM
