Usdm ek hatch swap
Old Mar 26, 2021 | 06:16 AM
BseriesWill's Avatar
Default Usdm ek hatch swap
Hey guys! I'm gonna be straight up, cuz i'm in school and trying to do a budget na build. I found a full B20z2 swap for 1200: motor, trans, axles, non vtec stock head, pr3 b16 vtec head, two blown trannys, one of them is the type r b16 trans, trans rebuild, and diff. I believe he's even got the correct wiring harness for the swap, and not quite sure on ecu. Where do I even begin? My end goal is a cammed b20z2 na build, with a choppin cam and possible wet kit.
Should I go non vtec and sell the pr3 head?
What cams would work best, and would I need pistons for valve clearance?
Would a 75 shot be realistic if the hellkitty pulls up and wants a race?
Motor mounts are also a concern, as they can get quite pricey. Might have a buddy with the ones I need, but what do you guys recommend?
I could mismatch ratio's as well between the trans, and I'm really not sure what I would want for an NA build.
I am starting at ground zero, and I was hoping that I could get my questions answered directly instead of spending hours searching for the thread I need. Any help would be greatly appreciated, and please correct me if I have said something wrong. Constructive Criticism is greatly appreciated, and I will consider everyone's advice. Thank you!
PinchE NegRo
33
Dec 17, 2016 04:54 PM
16bek
Sep 1, 2010 05:35 PM
dth0ng69
Oct 8, 2009 09:12 PM
80 dolla crx hf
31
Apr 27, 2009 08:56 AM
EFstyle
Jul 2, 2006 03:36 PM
