ATI Super Damper on B16B Keyway Question
Old Mar 24, 2021 | 08:33 AM
kraquepype's Avatar
10 Year Member
Default ATI Super Damper on B16B Keyway Question
I got around to installing my super damper on my engine, once it was pressed all the way on I could see the crank key isn't large enough to completely fill the entire keyway. It went on smoothly without much fighting.
Will this be a problem? I imagine being a press-fit it would be OK but wanted an opinion.
I don't feel any increased vibration or see any wobble but I only took it for a short test drive. I'm hoping this will be some insurance against a blown oil pump.
Thanks
Old Apr 21, 2021 | 05:06 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: ATI Super Damper on B16B Keyway Question
Thanks
I believe some keys are tapered, i wonder if you put the key in backward but i would take it off and inspect and try another key, last thing you want is the pulley to move throwing off timing..
Old Apr 22, 2021 | 10:28 PM
Tuopponen's Avatar
5 Year Member
If the pulley turns it does not affect timing. Only if you turn the distributor manually or tune timing from ecu.
Old Apr 23, 2021 | 05:19 AM
Chance EG's Avatar
Mechanical timing...
Old Apr 23, 2021 | 05:31 AM
Tuopponen's Avatar
5 Year Member
Still the crankshafts timing belts gear has its own key to keep it in time...
So as long as the balancer pulley is in there and the crank bolt is on the timing does not change.
Old Apr 26, 2021 | 06:05 AM
kraquepype's Avatar
10 Year Member
I took a look at it recently and it hadn't moved after driving it for a few weeks. The key is not tapered, but looks like it could a be little thicker to fill up the keyway better.
kraquepype
Apr 2, 2021 12:49 PM
phyzJunkieCivic
Nov 7, 2006 01:09 PM
kool168
Nov 9, 2003 06:06 PM
Kevin
May 20, 2002 02:33 PM
