Please HELP Crazy TPS calibration issues
Old Mar 22, 2021 | 09:22 AM
toki's Avatar
Default Please HELP Crazy TPS calibration issues
I have a JDM H22A swap in my EJ1 Civic ("EG coupe"). I've had this swap in the car for 11 years now, I had to replace my TPS twice in 2017, the 2nd one I used an OMNI and it worked fine until last summer, the car has been my daily since 2016. I was able to calibrate it without issue both times.
last August I was able to get closed throttle to 0.5 but WOT only up to about 4.1, this worked fine until here recently. I checked the calibration and it gave 11.3 V at closed throttle and then 7.7 V at WOT. Obviously these numbers are wildly out of spec and moving backwards. So I put in a new TPS to get the same wild crazy readings.
I'm honestly quite stumped here. Theres no way the wires spontaneously reversed themselves and I am definitely not mixing up the MAP plug as my map is on the other side of my intake manifold near the firewall.
My ECU is a chipped P28 I got from Phearable.net to replace my buggy JDM prelude ECU about 4 years ago in early 2017. Idk if my ECU is somehow causing these wild TPS readings or what.
Somebody please help!
Old Mar 22, 2021 | 11:30 AM
ross2004's Avatar
Default Re: Please HELP Crazy TPS calibration issues
Something is very wrong there, obviously. Check the outer two pins on the TPS plug, you should have 5v with the key on. Getting anything over 5v on the signal (middle) pin is not right at all.
Old Mar 22, 2021 | 01:27 PM
toki's Avatar
On the yellow wire It says 7.1 V, this one should be a constant 5v. This time around I am using a new multimeter maybe it is faulty? It's a cheap one from AutoZone.
if that's not it then what in the heck could be making it do this?
Old Mar 23, 2021 | 12:16 AM
TimiK's Avatar
10 Year Member
those cheap aftermarket sensors wont work well
Old Mar 23, 2021 | 05:12 AM
ross2004's Avatar
If it truly is 7.1v and not the 5v it should be, I would try swapping in a different ECU.
Old Mar 25, 2021 | 12:17 PM
johnnybgood1's Avatar
Check 5v reference at all the other 5v references. See if it's the same reading.
Old Mar 26, 2021 | 09:10 AM
toki's Avatar
Thanks for this tip. I swear I'm not being lazy. I've spent a good half hour searching for other locations I can find a 5v reference, I get alot of MAP sensor threads in my search results.
where else can I find a 5v reference on an OBD1 harness?
Old Mar 26, 2021 | 09:29 AM
ross2004's Avatar
MAP is a 5v sensor, see what you get on that plug.
Old Mar 26, 2021 | 10:13 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The IAT is 5v too.
Old Mar 26, 2021 | 10:18 PM
engine coolant sensor
if they all have the same out of range 5v ref then the ecu is bad
cranker
Jul 15, 2010 03:22 PM
Atech77
Feb 15, 2010 08:17 PM
preludecraz
Nov 13, 2008 02:30 PM
raiden571
Jan 14, 2008 03:44 PM
wade
May 31, 2004 12:32 AM
