Power window issue
Old Mar 21, 2021 | 04:47 PM
TrevorSchneider's Avatar
Default Power window issue
Ok so I just bought a 95 4 door civic recently. The power windows didn’t work when I got it and the kid I got it off of thought it was the drivers door switch. Well it is not the problem from what I can find. All 4 widows don’t work. I have checked the relay under the dash, all the fuses in the under dash fuse box, all the fuses in the under hood fuse box. All of the fuses are good. I also tested all the fuse locations in the under dash box I have power to all locations except the 4 window fuse locations. Could my under dash box be bad? At a lose need help pin pointing the problem
Old Mar 21, 2021 | 05:31 PM
fonkernuckle's Avatar
Default Re: Power window issue
Maybe this can help you you can skip and start to minute 5
Old Mar 21, 2021 | 05:33 PM
I would say its the relay but thats a guess since all 4 fuses are controlled by the relay but its just a guess check out his explanation/ work
Old Mar 27, 2021 | 07:47 PM
fryman's Avatar
Wiring diagram and a multimeter is the best way to track down the problem. My guess is that water got inside the driver side door harness and damaged some of the contacts for the window wiring. I've seen it happen before, infact my power locks aren't working currently because of that. Try opening you door to reveal the driver's door harness, then pull the rubber boot off the connector and see if it's full of water. You can also detach the connector and check for corroded contacts or broken wires but you may have to remove the fender to make that easier.
99_<ivi>_SI
Nov 14, 2012 05:01 PM
hondahustle
Jun 12, 2012 06:04 PM
GooseS2000
Dec 23, 2011 07:59 AM
toronto_thunder
May 2, 2008 06:36 AM
gaccord00
Nov 9, 2004 08:00 PM
