Head bolts
I am presuming this is a F23A engine : Torque them to 22lb. and then turn 90 degrees twice. If they are new bolts do a third 90 degree. You will start at the back center and work your way out, alternating side to side.
If you search the forum you should be able to find this for anything else on assembly, I believe.
toddhunter
Engine Machining & Assembly
May 27, 2019 08:19 AM
junglerunna
Jan 20, 2005 09:31 AM
