Help! Mini me swap crank no start!!
Old Mar 15, 2021 | 06:01 PM
William Isabell's Avatar
Default Help! Mini me swap crank no start!!
1995 honda civic ex d15b7 block d16z6 head new z6 distributor p28 ecu. Getting spark and fuel and timing is spot on but not starting. Any ideas?
Old Mar 18, 2021 | 06:06 PM
fonkernuckle's Avatar
Default Re: Help! Mini me swap crank no start!!
One thing when you put the timing belt back on were the timing marks on point on the compression stroke piston 1 TDC and not the exhaust stroke? What marks did you use on the head/ camshaft wheel for timing belt timing.
Old Mar 21, 2021 | 07:26 AM
It was on the compression stroke and I used the up mark and the timing mark going to the pointer on the timing cover at about the 6 or 7 o'clock position
Jake Bauer
Aug 21, 2017 01:32 PM
ascarberry
Apr 21, 2011 03:46 PM
ozzyman
Sep 9, 2008 11:50 AM
Ultraspeed DC2
Mar 29, 2008 07:59 AM
dr_latino999
Dec 2, 2004 09:55 PM
