Alternator failure after wash
Old Mar 15, 2021 | 07:42 AM
Kolusion's Avatar
Icon5 Alternator failure after wash
Hey all
So I decided to hose down my engine bay. I covered a few things with a plastic bag, including the fuse box, but I didn't cover the alternator because I wasn't planning on starting the engine for a couple of days after by which time the water that got inside the alternator should have evaporated. Regrettably, the alternator has failed.
After starting the car, the battery warning light came on. Also, the alternator was making a squealing noise. See the video here to hear the sound at 1500 RPM, 1100 RPM and 800 RPM (barely makes any sound at 800 RPM).
https://streamable.com/10vaap
My battery went flat in just over an hour.
I have checked both the ACG(S) fuse (37) and alternator/fuel pump fuse (12). Both are are fine. I also disconnected the alternator power cable and let it sit overnight to allow any water that may have gotten inside to evaporate. This didn't help.
The fact that the alternator is now making a squealing noise makes me think the problem is mechanical rather than electrical but perhaps its both.
What do others think?
Old Mar 16, 2021 | 05:27 AM
ross2004's Avatar
Default Re: Alternator failure after wash
Sounds like it's dead.
Old Mar 16, 2021 | 08:04 AM
Kolusion's Avatar
That's not what I wanted to hear but thanks for comment!
Old Mar 21, 2021 | 12:55 AM
CiGHonda's Avatar
I've sprayed my alternator during numerous engine washes over the years. The important part is to run it after the wash and let heat get rid of any water. Letting it sit might have been the issue. One last try just let it run for a while and see if somehow it can burn off whatever is in there.
Old Mar 22, 2021 | 05:04 AM
Send Ludes's Avatar
Sounds like the shaft bearings went bad. That's the noise you'd get when they fail. You'd most likely need a new one.
Old Mar 24, 2021 | 09:44 AM
Kolusion's Avatar
So I cleaned out the alternator connector and the port that it plugs into with two passes of WD-40. These things were filthy! Check it out...
https://ibb.co/NFF5XRp
https://ibb.co/x24Jfsd
This is the result of the port after the WD-40...
https://ibb.co/FgLGcZx
Cleaning the connector and port didn't resolve the issue, so now I am pulling apart the alternator to degrease everything with WD-40 and repack the two bearings with bearing grease.
I have hit a problem dissembling the alternator because Denso wanted to be impractical and seal the case with a shitty design. I am hoping someone can help me with it.
There are four nuts and four of something else with threads that hold the case together. I have removed the nuts but I don't know how to remove the thread things. Check out the photo's to see what I mean...
https://ibb.co/NpKfZqh
Does anyone know how these thread things can be removed?
So far, this is what I have removed...
https://ibb.co/9TC69Fn
This is the brushes and slip rings. I don't think they are the problem but if anyone can see something that isn't right then please let me know...
https://ibb.co/LZDgQk8
https://ibb.co/JCGwD4f
Old Mar 25, 2021 | 12:14 PM
johnnybgood1's Avatar
Since you didn't take a picture of the bolt head end it's hard to tell what the issue is. Take a better picture of the head of that bolt. It's possible you may need an impact driver to unstick that bolt.
https://www.harborfreight.com/6-bit-...ase-64812.html
All the components are so beat up it's going to be best to just get another from rockauto.
Old Mar 26, 2021 | 06:05 AM
Kolusion's Avatar
I didn't take a photo of the bolt head because there is nothing to look at. A person who has dealt with this type of bolt would know the solution from that photo.
I found out what I have to do to take it apart from watching a couple of YouTube videos of other people taking apart their alternators. The bolts are not threaded in the centre but the casing is stuck together as is. You need to beat the casing to vibrate it apart.
I don't have the time to wait for an alternator to arrive from rockauto. I need to fix this alternator yesterday!
That impact screw driver set you posted it so awesomely cheap! The cheapest one at my hardware store is five times the price and comes in a hippie colour!
https://www.bunnings.com.au/kincrome...r-set_p0018310
I needed one of these to remove two of the diode screws which were so tight that I stripped the heads and had to rip them lose with multigrip pliars due to not having screw removal pliars.
Old Mar 27, 2021 | 08:40 AM
Kolusion's Avatar
So I got the nut off and proceeded to separate the alternator housing but can't I do it. Here's a video of me explaining the problem while demonstrating it...
https://streamable.com/8zxp3c
Old Mar 27, 2021 | 10:15 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Take off the pulley. Then try to separate the housing.
See this video:
Old Mar 28, 2021 | 04:42 AM
Kolusion's Avatar
Yes, Honda fucked up the shop manual and the pulley actually does need to come off when replacing the rear bearing. As I damaged the alternator while banging it with a hammer and it's become too much of a hassle to get the parts for a repair, and that I am getting rid of the car in 11000 kilometres, I am just going to get a second hand alternator or an OEM unit to keep me going, what ever's cheaper.
Thanks for your help!
Old Apr 8, 2021 | 09:47 AM
Kolusion's Avatar
// Face palm // I knew I should have gotten a multimeter to test the alternator when this problem started but I didn't get one due to circumstances outside of my control.
So I fully charged my battery and installed the new alternator and the battery light was no longer coming on. Great I thought, but the belt was squealing a lot, so I started trying to find the cause. After about 30 minutes with the engine running, my battery light turned on again, and it turned on as soon as the fan came on. Perhaps the battery light didn't come on at the start because it was fully charged but then came on when it started to run down.
So I then had a closer look at everything. Knowing it can't be the alternator, I followed the alternator belt and noticed that the crankshaft pulley was wobbling, and when it wobbles it looks like it has split apart. That abnormal pulsing sound is still present and I am wondering if it has something to do with the crankshaft pulley.
The alternator belt is spinning the alternator pulley so the alternator must be charging?! But I don't know. I temporarily tightened the belt even more but it didn't make a difference.
The problem was not happening before this abnormal pulsing sound so what ever is causing this sound probably has something to do with it.
I followed the cable from the alternator to the fusebox. It looks all good. I cleaned the alternator wire connector again with WD-40 and scraped the terminals with a metal paper clip, and even sprayed WD-40 on the alternator wire connection in the fusebox, but nothing has helped. I am starting to lose patience with this car, it is wasting my life and I have started having visions again of a tow truck coming to pick it up and taking it to the wreckers!
If anyone thinks the problem may be something else then please let me know!
Also, does anyone know where in the shop manual I can find the procedure for replacing the crankshaft pulley? I have looked but can't find it.
I have taken some more videos of the problem...
Wobbly crankshaft pulley...
https://streamable.com/4okumi
Pulsing sound (really noticeable at 34 seconds), and the battery light comes on with fan...
https://streamable.com/9ik6bi
Old Apr 15, 2021 | 10:34 AM
Kolusion's Avatar
So I got the fender liner and front splash guard off today and inspected the crankshaft pulley. It has defused where the rubber is...
https://streamable.com/1tnn9s
I also took off the power steering belt and confirmed that my power steering pump is what is making the noise. This does not surprise me because I am actually in the middle of changing my power steering fluid. I was waiting for the bubbles to settle in the power steering reservoir which is why I killed some time and cleaned my engine bay which is when all of these problems began. I checked the power steering fluid tonight and it is sitting on the low line. Perhaps that is why my power steering pump is making an abnormal noise.
I couldn't remove the power steering pump in accordance with the manual because access to the pulley bolt and adjusting bolt are inaccessible with my convention spanners and ratchet. I had to get it off by removing the power steering top bolt and and loosen the bottom bolt. A real **** design.
I'm really hoping this problem goes away after I change the crankshaft pulley. So there was nothing wrong with my original alternator and I doubt that there is anything wrong with this new remanufactured alternator. The fuses are good. The wiring looks good. All that can be left wrong now is the alternator belt or crankshaft pulley. The belt is cracked like hell which you can see in the video, but the fact the crankshaft pulley is broken makes me think it's that causing the alternator not to charge. Who knows though? Now that I know the crankshaft pulley is not the cause of the noise, I'm wondering how long has the crankshaft pulley has been defused? Perhaps it's been defused for ages but still functions and it's really the cracked up alternator belt causing the alternator not to charge! After all, this problem started after I hosed down my engine bay. Perhaps when the water dried, it dried out the alternator belt? This thought gives me a sick feeling! But then perhaps the water dried out the rubber fusing on the crankshaft pulley?!
My crankshaft pulley arrives next week, let's see what happens. ****** cars!
Old Apr 16, 2021 | 06:30 AM
Kolusion's Avatar
Well I got the alternator belt off the crankshaft pulley tonight and can confirmed it is the culprit to the alternator not charging. The outer part has complete defused from the rubber.
https://streamable.com/1vy2zo
I have been able to have a closer look at the belt. It's no where near as bad as I thought it was. It will easily last till I get rid of the car.
Perhaps me running the power steering with low fluid caused it's pulley to be harder to turn which in turn put pressure on the crankshaft pulley causing the inner and outer part of it to separate. I didn't fully top up my fluid as my car is parked on an incline which is why I was waiting for the bubbles to settle, to get an idea where it was at and top up a little more before I drive it to a flat road to complete fluid top ups.
I have noticed the engine knocking with all the belts off. Just an observation.
So I am not going to buy the special tool to remove the crankshaft pulley bolt and instead will use a hack. I am not going to have a look at hacks tonight as I am tired and need a break from the car but does anyone have any ideas they could share with me?
I also need to know a hack to get it back on again. The replacement crankshaft pulley is from a 1989 Prelude.
eggie75
Mar 25, 2010 04:37 PM
Choy
20
Jul 20, 2009 07:11 AM
macsmurray
12
Jun 14, 2005 02:36 AM
crxaddikt
Audio / Security / Video
Jan 28, 2003 02:34 PM
