Suspension & Brakes Theory, alignment, spring rates....
spline conversion 26 to 28 on output shaft
Old Mar 13, 2021 | 07:50 PM
emuplanet's Avatar
Default spline conversion 26 to 28 on output shaft
i have a 1988 honda accord
i am swapping over to 4x 114.3 in the front i got 1g legend front knuckles.. didn't fit at all read that the 4g accord knuckles will fit.. but the hub is 28 spline and the output shaft is 26 spline on my 3g accord 3g accord uses 32mm axle nut.. 4g uses 36mm
i have axles from the 1g legend which are 30 spline, but 36mm axle nut as well, so i am assuming these will be somewhat close to the 4g accord axles...
i need someone's help lol... I'm all over the place i just want these gd 4x114.3 hubs
emuplanet
Welding / Fabrication
Mar 13, 2021 07:50 PM
emuplanet
Mar 13, 2021 07:49 PM
emuplanet
Transmission & Drivetrain
Mar 12, 2021 07:38 PM
gta_killer_19
Apr 16, 2020 03:00 AM
