Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Low Idle when stopped or when car is driving
Old Mar 11, 2021 | 06:37 PM
Camry12's Avatar
Default Low Idle when stopped or when car is driving
Car: 2004 Honda Accord EX-L Coupe V6 (NAVI) AUTOMATIC
Hello there, just got my hands on this beauty of a car but its having problems with the RPMs. I was driving it around the other day and noticed the RPM gauge needle was almost at 0. When I came to a stop the car was about to stall and I saw the battery light (red light) so I gave it gas and it steadied for a second and I continued to drive home.
What I've done:
-Used throttle body cleaner on> Throttle body, EGR valve and Intake manifold.
-I purchased a MAP sensor and when it arrives I will install it.
I am really lost and would love to fix this issue on this car. This generation Accord, the coupe version, is one of my all time favorite vehicles and I'm so stoked I finally own one. Please give me some pointers, thanks for reading.
Old Mar 11, 2021 | 06:51 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Low Idle when stopped or when car is driving
The battery indicator light is related to the charging system. Get the alternator and battery tested. Many auto parts stores will test for free.
Old Mar 19, 2021 | 06:06 PM
Camry12's Avatar
Found out it was the RPMS gauge itself. Mechanic quoted me $600 to purchase a spedometer from honda and to install it. So I'm gonna find one myself and replace it, or see if I can replace the RPM gauge motor itself
Old Apr 4, 2021 | 07:50 PM
07Euro's Avatar
Interesting. As per Tech8, this sounds a lot more like a bad battery problem. I had a similar problem on my car not long ago.
The alternator would be normally the second thing to check which can be done at the same time.
Throttle body and intake clean is always good to do also, but you'll generally find it makes the car idle and run rough, but not make it stall unless it's completely blocked.
Doug05STI
Honda Civic (2006 - 2015)
Nov 6, 2020 03:03 PM
bamage
Aug 3, 2009 08:20 AM
hueyjock
Feb 10, 2009 04:29 PM
ChinitodeNJ
Jan 9, 2009 08:50 PM
groundedcivic91
14
Feb 9, 2005 08:46 AM
