Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
2006 Civic hybrid door lock / FOB issues
Old Mar 9, 2021 | 02:50 AM
1wombat1's Avatar
Default 2006 Civic hybrid door lock / FOB issues
Hello, so my last key in my possession failed and I had to rebuild my ignition and reset the chip in two new keys with my launch. engine starts keys work great.
Problem: can not reset the two new fobs, all methods I tried failed.
Related Issue: When I put my key in the ignition and switch to on position all the doors lock, when I turn it to off it opens all doors. Over and Over
Also the arm rest door switch opens all doors but fails to lock them, no sound at all when trying to lock. I have had both problems since I was hit in the right side years ago and the auto body did something bad to the car while fixing it.
I asked them they said it just needs to be reset. I didn't bother because I rather liked to doors locking and I forgot about it, but they lied. While doing the ignition repair I noticed the fuse box in the interior had a fuse for the door I think #10 that the metal tabs were broken off on the 7.5 fuse but it still worked.
I think they may have shorted something and maybe melted the fuse box so they got it to work by breaking the tabs. Anyways all doors lock when the ignition is on and the interior lock switch does not lock any but opens all. Also the exterior door lock locks all doors and sets alarm, and also opens the doors but the alarm goes off so you must stick key in ignition and press the alarm reset button.
Possible Fob program Failure: Because the doors lock when I try to reset the FOB's by moving key to on position I think this may be part of the reason why I cant program the FOB's.
I figured if I found my key I lost over 5 months ago maybe that might work having a working fob, well I found it in my garage today ran out tried the fob and nothing. FOB lights work great, even replaced battery but I think my attempts to re-code the other fobs reset the programing different from the old Key Fob
Tomorrow I will reprogram the Key chip on the found key to the others but I am at a loss as what to do next.
HELP: I figure Ill need to fix the internal door lock / Ignition lock issue first in order to try to program the FOB's, does anybody have a clue as to what is going on, I cant find this issue anywhere?
Also I can't reset to any of the 3 door lock scenario programs probably due to the doors locking when the ignition is turned on.
What say You, any help is appreciated, thanks
ReneB64
Oct 6, 2017 08:19 AM
shiru
Honda CR-V & Element
Oct 22, 2016 01:56 PM
93dakc
Jun 14, 2012 12:53 PM
eddies_ls88
Feb 2, 2012 10:25 PM
MisterMonkey26
Aug 27, 2009 12:34 PM
