B20v tb cable issue
Old Mar 8, 2021 | 05:08 PM
Team Loyalty's Avatar
5 Year Member
Default B20v tb cable issue
Hope everyone doing good and safe I have a b20v with gsr head and a victor x Intake . So my issue is my tb open only at 75 percent full throttle they told me I need a tb bracket and a new cable shorter does anyone know which bracket and cable I need . Motor on a Ek hatch . Or anyone know if I can adjust my gas pedal or etc and another ? I’m going to get tune soon so I need to finish this issue and another which spark plug so I need range 7 or 8 or 9 I heard range 9 cause I’m going to throw 75 shot dry when I go tune if anyone know Thanxk and thr gap to Thanxk
Old Mar 9, 2021 | 01:45 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: B20v tb cable issue
Heat range 8 should be fine for a NA "B" series with a 75 shot.
What throttle cable do you have now ? Do you have the original Edelbrock throttle cable bracket or are you using something else ? What brand throttle body are you using and for what application ? Is the throttle wheel removable so that it can be "clocked" at another position to get more/less pull ?
Old Apr 29, 2021 | 07:31 PM
wunfstgsr's Avatar
Loved
Community Favorite
I would think a B16 or ITR cable should work
Old May 23, 2021 | 10:39 PM
GIZZ - EXV's Avatar
Loved
I've been through the throttle body issue. I emailed the TB manufacturer and no response. I contemplated making a new pedal arm until I came up with this idea. I figure most of the people running aftermarket throttle bodys don't have wide open throttle. I did a vid on the situation once I figured it out, today I actually made up another pulley with a cam profile that opens slower in the beginning of pedal travel. This helps with a 74mm TB, otherwise you barely touch the throttle and its like Im flooring it.
Hiboost 2.0
May 17, 2013 05:33 PM
Autoworks
Mar 10, 2005 04:19 PM
98HB
May 7, 2004 10:19 AM
whiteblurr
Jan 19, 2004 07:06 PM
