Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Honda accord 2003 vtec cutoff
Old Mar 8, 2021 | 11:21 AM
Charbelakiki's Avatar
Default Honda accord 2003 vtec cutoff
Hello,
I have honda accord 2003, ivtec dohc 2.4, manual transmission
I have recently installed a new engine.
But i have this problem : after driving 10 minutes, when the rpm hits more 2700 rpm, the engines cut off and stop fuel pumping.
i cleared the odb codes, but when this cut off happens, the code appears 2646
Raw code: 2646
ECU: 11
Status: Confirmed
OBDII: Rocker arm actuator A, bank 1 - performance problem or actuator stuck off
Honda: VTEC Oil Pressure Switch Circuit Low Voltage
The mechanical cleaned this vtec sensor but the problem still the same.
Plz. Help what could be the solution
Charbelakiki
Mar 16, 2021 04:44 PM
red_fangz
Jul 19, 2012 10:50 AM
Nick_G
Dec 3, 2008 12:03 PM
bradp
Jan 14, 2007 10:12 AM
gauto5150
Jan 4, 2007 04:22 PM
