Steering wheel
There is a great resource for this, I will list the core answer for you, and also the link, because the link has further details. There are two main types of steering wheels in this era, 33 spline and 29 spline. Looking at the below, you can see which should fit which car.
ALWAYS CHECK THE LINKS AND SEARCH SO YOU DON'T RUN INTO PROBLEMS OTHERS ALREADY HAVE EXPERIENCED.
The following Hondas use 33 spline:
98-02 Accord
03-07 Accord
08-10 Accord
03-07 Accord Euro R
96-00 Civic (377mm diameter)
01-05 Civic
06-10 Civic
97-01 CRV
96-00 Domani
97-00 EL
01-05 EL
01-08 Fit
09-10 Fit
99-06 HRV
00-06 Insight
97-01 Prelude
99-09 S2000
02-07 RSX
03-07 TSX
The following Hondas use 29 spline:
90-93 Accord (377mm diameter)
94-97 Accord
88-91 Civic
92-95 Civic
92-97 del Sol (371mm diameter)
92-95 Domani
90-93 Integra
94-01 Integra
88-91 Prelude (371mm diameter)
92-96 Prelude
For further details of hiccups in each combo, look here:
https://honda-tech.com/forums/tech-m...y-car-2842882/
98-02 Accord
03-07 Accord
08-10 Accord
03-07 Accord Euro R
01-05 Civic
06-10 Civic
97-01 CRV
96-00 Domani
97-00 EL
01-05 EL
01-08 Fit
09-10 Fit
99-06 HRV
00-06 Insight
97-01 Prelude
99-09 S2000
02-07 RSX
03-07 TSX
94-97 Accord
88-91 Civic
92-95 Civic
92-95 Domani
90-93 Integra
94-01 Integra
92-96 Prelude
Thanks a lot. Do you know if there is a adaptor to cross fit between or would I need a whole knew column shaft?
98-02 Accord
03-07 Accord
08-10 Accord
03-07 Accord Euro R
01-05 Civic
06-10 Civic
97-01 CRV
96-00 Domani
97-00 EL
01-05 EL
01-08 Fit
09-10 Fit
99-06 HRV
00-06 Insight
97-01 Prelude
99-09 S2000
02-07 RSX
03-07 TSX
94-97 Accord
88-91 Civic
92-95 Civic
92-95 Domani
90-93 Integra
94-01 Integra
92-96 Prelude
98-02 Accord
03-07 Accord
08-10 Accord
03-07 Accord Euro R
01-05 Civic
06-10 Civic
97-01 CRV
96-00 Domani
97-00 EL
01-05 EL
01-08 Fit
09-10 Fit
99-06 HRV
00-06 Insight
97-01 Prelude
99-09 S2000
02-07 RSX
03-07 TSX
94-97 Accord
88-91 Civic
92-95 Civic
92-95 Domani
90-93 Integra
94-01 Integra
92-96 Prelude
I’m so new to this, lol. What would it take just to put a whole new column in, would I need to source other parts? I’m sure the length wouldn’t be too much different, however, would it connect to other parts the same?
Just an opinion, but (to me) this would not be worth doing for a steering wheel. But that's just me, I would find a steering wheel that fit and just use that or go aftermarket. Not that it's THAT hard to take the steering column out, just not something I would want to do. And, as you mention, no idea if the other cars lengths are close or not.
If you want to kinda watch how to do a column, watch this, it's the wrong year, but gives you an idea of the complexity and your willingness to take all this apart.
Good luck
Good luck
