Would you go from 15x7.5 to 15x8?
Just curious as this is driving me crazy. For a turbo FWD B series, would you bother with the extra half inch? The wheels I have are 15x7.5 with +35 and I can go to the same exact wheels in 15x8 +35. Right now I run 205s with no rub and no fender roll.
Lowered at that. No problems.
If you can fit a 215 width tire on there without rubbing, which I've seen 15x8" wheels before and I don't think they rubbed, then you'd have about 5%more width. So if it's worth your money, then I'd say do it.
I think it depends how low your car is, but I remember seeing 8" wide on civic/integras before.
It all depends upon the purpose of the car. If this is still a street car I don't see any reason to go wide and and 15x7.5
Especially if it is really for the street more than anything else. I could easily see one go to an 8 or 8.5 for autox, short distances, tighter corners more often, but now you're limited on wheel choice. offset, and possibly overstretching a tyre to the point of stress, when the chassis is going through enough as it is when retrofitted with a turbo making over 400whp.
So, I'd K.I.S.S, and stick with the 15x7 and focus more on the tyre choice and wheel offset.
But I'm conservative like that....so
SantaCruz92Si
Jul 22, 2003 01:36 PM
