Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2004 Honda Civic Lx >40mph low toned, loud growling from front end
Old Feb 24, 2021 | 08:17 PM
R Moore's Avatar
Default 2004 Honda Civic Lx >40mph low toned, loud growling from front end
Hello,
I have an 04 Honda Civic LX, just recently it started making a low toned, loud growling from the driver front side. It only starts at 40 mph or above, it is amplified greatly upon increase in speed.
No additional noises are present if I turn left or right, I was thinking it would be bearing Orings and/or the bearing center hub itself. Can anyone shed some expertise light on this, please?
Old Feb 25, 2021 | 04:18 AM
NDNV's Avatar
Default Re: 2004 Honda Civic Lx >40mph low toned, loud growling from front end
Possible bad front wheel bearing - check both sides.
Old Mar 1, 2021 | 10:38 PM
ES2_life's Avatar
Having this same issue. Does it sound like a helicopter taking off? It’s hard to tell 💯% but seems mine is coming from driver side wheel bearing. I just purchased a wheel bearing off Amazon and will install this weekend. This should solve pro unless it’s cv shaft but highly doubt that. The sound is more humming like a helicopter which is 98% time a bad wheel bearing. If you are not sure I would definitely recommend taking it to a reputable shop tho for sure.
Either way let me know what you found was the issue!
EyePhoto
11
Sep 19, 2013 02:21 PM
odo53
May 22, 2008 06:30 AM
fe519
May 19, 2003 07:29 PM
J T*
Sep 28, 2002 10:20 AM
