Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
03 Honda Civic
Old Feb 24, 2021 | 10:09 AM
SherylG0928's Avatar
Default 03 Honda Civic
I have an 03 honda civic ex. It cranks and runs. But when I put it in drive or reverse it acts like it's in neutral. I don't know where to even start on trying to figure it out.
Old Feb 25, 2021 | 04:16 AM
NDNV's Avatar
Default Re: 03 Honda Civic
Engine runs, but vehicle does not move in any gear:
Low ATF level - use only OEM Honda DW-1 ATF
Shift cable broken or out of adjustment
Shift cable worn
ATF pump worn or binding
Regulator valve stuck or spring worn
ATF strainer clogged - internal clutch debris over time has cause a restriction in ATF flow to properly change gears
Mainshaft worn or damaged
Final gears worn or damaged
Transmission-to engine assembly error
Axle disengaged
Have you done any drain and fills of Honda DW-1 ATF every 30K miles? Do not flush the ATF. If not, the trans could have failed.
Nanderson303
Transmission & Drivetrain
Mar 26, 2016 09:17 AM
michellerocker
Mar 21, 2016 02:42 AM
jojo23
Jul 1, 2013 05:37 AM
Cmtd93
May 18, 2011 06:56 PM
clh2991
Nov 13, 2008 05:12 AM
