What engine bay harnesses are compatible?
Old Feb 23, 2021 | 08:16 AM
Canadian_EF's Avatar
Default What engine bay harnesses are compatible?
Hi guys,
I am having some trouble finding the answer to this dilemma.
I bought a nice 1989 Civic Si, but it didn't come with an engine harness. I obviously need one to proceed with the car.
I am wondering what harnesses are the same? Obviously the DPFI harnesses are not going to work for me, but would any 89-91 Civic Si harness work as well as the CRX Si?
I remember hearing that the harnesses are a little different from 88-89 to 90-91. Can anyone shed some info? I'm fine swapping the plastic connectors if they are different.
My biggest concern is the shock tower plug pinouts. I have found a pinout for the driver's shock tower, but it doesn't specify what year it is from.
Old Feb 23, 2021 | 12:44 PM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: What engine bay harnesses are compatible?
You could always buy an aftermarket harness from some place like MonoTech.
I'm sorry I can't help you with pinouts - I have extensive notes for a 1990 DX Auto that I converted to MPFI and 5 speed.
Old Feb 23, 2021 | 04:07 PM
kraquepype's Avatar
10 Year Member
I don't think much changed between 89-91 engine wise, they should be interchangeable. The aftermarket replacement harnesses I see are all indicated for 89-91 so my assumption there is that the tower plugs are the same.
The Monotech harness looks nice and uses the tower plugs. I have their OBD0 -> OBD1 conversion harness for the ECU and its held up with no issues.
Old Feb 24, 2021 | 06:08 AM
jlicrx's Avatar
89, 90 and 91 engine harnesses for the D16A6 are all the same for CRX Si, Civic Si, Civic EX (MT) and 4WD wagon (MT)
the 88 harness had a different driver's side connector since it didn't have a Fast Idle Control Valve - the connector is rectangular with only 6 wires instead of round with 8 wires
this is the 88 connector:
Old Feb 24, 2021 | 06:16 AM
kraquepype's Avatar
10 Year Member
Originally Posted by jlicrx
89, 90 and 91 engine harnesses for the D16A6 are all the same for CRX Si, Civic Si, Civic EX and 4WD wagon
My 89 Si didn't have a fast idle control valve on the D16 either, only the IACV. Thats the valve under the throttle body right?
Old Feb 24, 2021 | 06:39 AM
jlicrx's Avatar
89-91 FICV
Old Feb 24, 2021 | 10:11 AM
kraquepype's Avatar
10 Year Member
89-91 FICV
Got it, thanks, there was one of those on my A6. I was thinking of the FITV.
Old Feb 24, 2021 | 12:26 PM
Wow thank you! Yes! This is the community I love.
You have made my day @jlicrx
BigbamaBen
Dec 12, 2011 01:14 PM
showcivic96ex
Mar 18, 2011 12:16 PM
wolfsbain
Apr 16, 2010 01:03 PM
92civicboost
Sep 28, 2009 10:02 AM
skidmarkroyalty
May 16, 2009 08:07 AM
