I had removed the engine which was a 95 JDM ITR out of a 96 ek hatch and swap it in a 00 ex civic. I have this plug I have no idea about and want to make sure it’s not need before I try to start the car.
engine 95 JDM ITR
engine harness unknown( might be Lx/DX from ek hatch) everything worked on the hatch.
ECU is P05 chipped with Crome
car is a untouched 00 ex civic.
2 attachments are for the plug I have no clue about 1 attachment is of the ek hatch engine is being removed from
that’s the harness that came with the motor when it was removed.
So. This doesn't mean it is correct for your application. You have already admitted that the swap came out of a '96 Civic. For the best swap operation over time, it is recommended to use the engine harness that originally came with your chassis (or a replacement that is EXACTLY like it), and modify it to fit/plug in to the engine that you are dropping in.
It is possible to convert the OBD-2A engine harness to work inside an OBD-2B chassis, but it is WAAAYYY more work than is necessary... and once you start down that rabbit hole, you are committed. If you make ANY mistakes, you will have to replace the entire dash harness AND engine harness... so this is not a job for the rookie wrench turner. So, just do as I suggested above and you will be fine.
A 99-00 Civic Si "EM1" harness will be 100% plug-in for your engine, except for possibly the distributor. depends on the year of the distributor currently on the engine.
Next closest option is a 99-01 CR-V manual trans harness. Same deal with the distributor plus you will need to add VTEC wiring.
Third best option is repurposing your EX harness. Will take some massaging plus the distributor issue.
Unplug the green connector NOW. They are not cross compatible between generations and you may have a bad day if you power on the car.
