Crank, no start 1990 honda accord lx help please tried everything
Old Feb 17, 2021 | 10:44 AM
Hondaf's Avatar
Default Crank, no start 1990 honda accord lx help please tried everything
I have a 1990 honda accord lx and I have been trying to figure out my no spark issue for three months and I'm about to scrap the car because I can't figure it out. I have read and tried everything I have seen on here about it. I first replaced the distributor after finding out I had no spark , then I replaced the main relay still nothing then I tracked down the engine grounds and cleaned and inspected them all, after that I tried reading engine codes by counting the flashes on the ecm and it had no codes stored. I tested the coil on the distributor and it has power to the coil so I bought another new coil still nothing. And yes I checked all the fuses
What else could it be??? Please help !!! sorry for the long post and if I didn't do it right
Old Feb 17, 2021 | 03:03 PM
99stockcivic's Avatar
Default Re: Crank, no start 1990 honda accord lx help please tried everything
Hmmm... I'm just thinking of anything, I have no idea the likelyhood.
If you take the distributor cap off, when you crank it up (turn the key to start it), does the distributor rotate? If it's not rotating, I would suspect a broken camshaft.
If it does turn, maybe it's the crank position sensor?
I would take off the valve cover to look and see if anything is broken or jammed or fallen off
Old Feb 17, 2021 | 04:26 PM
Hondaf's Avatar
Thank you for the response I have checked and made sure the rotor was turning already
Old Feb 17, 2021 | 07:33 PM
So you can see power at the coil, the rotor is turning, but no spark at the spark plug?
Is there power at the cap?
Old Feb 18, 2021 | 05:54 AM
Hondaf's Avatar
There is power to the coil but not thru it nothing to the cap it still acts like the coil is bad even tho this is my second new coil
Old Feb 18, 2021 | 06:15 AM
Are you able to check continutity from where the coil plugs in to the cap? Seems like the break is there?
Puma63
Feb 8, 2018 10:49 AM
sharaaz2001
Nov 18, 2016 04:01 AM
ray chong
Sep 30, 2015 05:10 PM
sythe21
Aug 29, 2011 05:56 PM
civicboisi
Nov 29, 2009 06:09 PM
