My heater and radio only work in accessory mode help a girl out please
Old Feb 15, 2021 | 01:20 PM
Deb Walton's Avatar
Default My heater and radio only work in accessory mode help a girl out please
Honda civic 1991 my heater and radio only work in accessory mode what do I do I'm cold and I drive my car alot
Old Feb 15, 2021 | 02:35 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: My heater and radio only work in accessory mode help a girl out please
For the radio, check under-dash Fuse No. 12 (15A).
Give more detail how the heater doesn't work. Is the fan blowing air inside the car?
Old Feb 16, 2021 | 09:20 AM
Deb Walton's Avatar
Fuses are fine heater only blows in accessory mode as well as lighter and stero
Old Feb 16, 2021 | 11:09 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Sounds like a faulty ignition switch (electrical portion).
At the under-dash fuse box, brown connector C929. Turn the ignition switch to the 'Run' position, test for power on the wires.
The following wires should have power when the ignition switch is in the 'Run' position:
  • Yellow
  • Blk/Wht (black color wire with white stripe running through it)
  • Blk/Yel (black color wire with yellow stripe)
  • Wht/Blk (white color wire with blk stripe)
If you have power at some but not all the wires, then the ignition switch is probably bad.
Old Feb 17, 2021 | 03:39 PM
Tyson's Avatar
yeah i agree its likely the ignition switch. sometimes just spraying WD-40 into the key hole. usually just taking it apart and cleaning the contacts with isopropyl and applying new dialetrric grease will make an old one work as new.
https://honda-tech.com/forums/acura-.../#post51114762
did your car ever get stolen? when someone stole mine and used a screwdriver to start the car, it just took a bit of cleaning of the ignition switch to get to work again.
ms beats
Nov 14, 2014 02:30 PM
CivicInUse22
10
May 10, 2014 11:06 AM
jakscivic
20
Jul 6, 2006 12:52 PM
DJ Gurgla GSR
Audio / Security / Video
Apr 3, 2006 11:35 AM
BoRiCuA
Jun 13, 2004 05:21 PM
