2000 Honda Accord not starting after replacing Fuel Relay, Fuel Pump, Checked Fuse
Hello - i own a 2000 honda accord V6 and have 260K miles, i love my car but it wont start. I checked the fuse, i replaced the fuel relay, replaced the fuel pump and it wont start. See picture of lights below. the green light keeps blinking
I remember before it stopped i had the brake light come on, and i never checked or fixed it. Then all the error lights came up and it just wont start. Today the speedo and tachometer hand seem to be under the resting spot. Please help,thx
Reason: need to add engine size
You can also buy an immobilizer from the dealer, however I believe you will need to reprogram your keys to work with the new immobilizer.
It's going to look like this: https://www.ebay.ca/itm/98-01-Honda-...8AAOSw9hpf~9vH
I think the above will work, but like I said you will still need to reprogram it.
Hopefully it's just a fuse.
Thank you Sir - i checked the fuse and fuse is OK. I also tried all 3 keys i have and it keeps blinking. I think i will buy the immobilizer from dealer. How difficult is it to install and also how difficult is is to reprogram the keys ? thank you
Re: 2000 Honda Accord not starting after replacing Fuel Relay, Fuel Pump, Checked Fus
Originally Posted by tech8
Have you tested the battery or try jump starting the car? A low battery will prevent the Immobilizer system from functioning properly.
I just checked the battery its reading 11.9Volts. battery is about 5 years old - do you think this low enough to cause it ? the battery allows me to crank the car all the time but it just does not start, thank you
Reason: more data
To reprogram the immobilizer is using a tool. The one I like to use is called the CK-100+
You can read about it here: https://www.key-programmer.com/ck100/
Really all you do is plug it into the ODB-II port, then reset all the keys, then bring each one into the key lock and turn it partway, then tell the programmer this is a good key and it is now paired.
Not really very hard with the right tools. And...you can also then sell off the tool when done, someone is always in need of one.
