Need advice for repairing or replacing electrical connector
Hey folks!
I have a 2006 Accord EX V6 throwing a few P0443 codes. As I was looking around, I discovered the electrical connector is severed at the vapor purge valve. Is there an easy way to repair or replace this connector? It seems the other end goes straight into the main engine wiring harness.
I’m a novice with engines, having picked up a bunch from my dad. But, I’m very limited when it comes to electrical stuff; most of my experience there is with IT network cabling.
I’m really hoping I don’t have to replace the entire wiring harness!
Re: Need advice for repairing or replacing electrical connector
Originally Posted by SmithersJr
Thanks! Amazon says that will fit once I plugged in my car’s info. For $10, I’ll try it. 😁
If it doesnt work you are guaranteed to get the connector here. We have used them for years here at our shop(just replaced an S2000 TPS connector a few days ago.)
They are not cheap(around $75-$150) but guaranteed to have what you need or they will make it.
