Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Visual clues to R18A
Old Feb 13, 2021 | 08:47 AM
4drEF's Avatar
Keyboard Humorist
Default Visual clues to R18A
I am in need of a replacement engine for a cracked 2006 block. Cracks are the result of the factory flaw that result in water leaking out. (Out of warranty period and can no longer be replaced by Honda for free.) I tired the JBWeld fix and it has blown off after about 6 months.
Are there any visual clues to differentiate the factory flawed R18A to a newer revision that had this issue corrected?
My understanding is that 2009/2010 as well as warranty replacements have updates that are not prone to the cracking issue.
Apparently the R18 in 2011+ has a different way to sense the crank position and it isn’t compatible with the 2006~2010 method.... so that block can’t be used ☹️
Old Feb 13, 2021 | 12:18 PM
Chrisfrom1986's Avatar
Default Re: Visual clues to R18A
If you can find an RDOT block that would be your best bet. I'm not aware of any date stamping on the R18 block itself.
Old Feb 24, 2021 | 09:52 PM
4drEF's Avatar
Keyboard Humorist
Any visual cue like thicker casting in the crack prone areas?
Old Feb 25, 2021 | 05:19 AM
No
lpina650
Nov 23, 2016 02:07 PM
Garage 808 Hatch
Welding / Fabrication
22
May 2, 2008 02:06 PM
g0tgot
Nov 1, 2007 02:31 PM
IndySporty
Jan 27, 2007 07:36 PM
JohnnyEF
May 29, 2003 01:05 PM
