Short Shifter for ATR CH1 H22A7
I think Cosmo made shorter linkages and a short shifter, you can inquite with them:
https://cosmoracing.com/en/honda-acc...-2-3l-4cyls-ex
I know the above links to something that probably doesn't work, it gives you the company and you can look around.
I wouldn't be surprised at this point if you had to make one or modify one to get it for your car.
If all else fails, any of the aftermarket K series shifter boxes and RSX cables will work with some slight modifications as long as you get the required shifter cable bracket for the H22 trans. Huge improvement over stock.
The Original Whitey
Jul 17, 2009 09:49 AM
mraza
18
Apr 10, 2007 08:53 AM
