1988 Crankshaft
Old Feb 5, 2021 | 02:00 PM
niko2020's Avatar
Default 1988 Crankshaft
Hello all,
I'm working on a D15B2 from a 1988 Civic DX hatchback. It threw a rod so its in the machine shop. The crankshaft is bad beyond repair per the machine shop. I have found a couple on Ebay. One of the crankshaft was pulled form a D15B2 with an automatic transmission. Mine is a 5 speed. Does it matter if the crankshaft was pulled from an automatic donor? would it fit on mine? Thank you in advance for your advise.
Old Feb 5, 2021 | 02:32 PM
jlicrx's Avatar
Default Re: 1988 Crankshaft
transmission doesn't matter, however, since you have an 88, you need to determine which crankshaft your engine had - the D15B2 was available in 88 with two different crankshafts - some had a smaller 22mm snout on the front end where the pulley goes on and also fits the oil pump - 89 and up (and some 88's) had the larger 24mm snout - if you have the smaller snout, you will need an 88 with the smaller snout - otherwise any 89 and up (or 88 with 24mm snout) D15B2 crankshaft will work
Old Feb 5, 2021 | 02:45 PM
niko2020's Avatar
Thank you so much for your response. I'll double check my crankshaft size and go form there!
Ef4doorwagon
Jan 11, 2015 09:10 PM
kevin67
Dec 20, 2011 04:57 AM
MOE@Hyper16Valve
Jul 15, 2009 11:54 AM
1lowz24
Jul 6, 2006 12:29 PM
civicwagonman
May 28, 2004 07:13 AM
