S40 Rebuild, cleaning inside recommended products
Old Feb 2, 2021 | 08:50 AM
sushibar's Avatar
Default S40 Rebuild, cleaning inside recommended products
Im planning to rebuild my S40 and i expect it to be very dirty inside.
What is recommended to clean both the tranmission and clutch housing inner side, aswell as the inners parts gears/shafts/hubs etc before reassembly ?
Ive read that aluminium is sensivite to acid.
Thanks
Old Feb 2, 2021 | 03:22 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: S40 Rebuild, cleaning inside recommended products
I didn't clean it out, it will just be a little residue of gear lube. I did clean the magnet with brake cleaner (non-chlorinated) and a rag. And every seal housing got cleaned with brake cleaner.
I use brake cleaner as it's supposed to evaporate residue free. Anything else, I was concerned would leave a residue that may act on the fresh fluid to some degree. I wanted to avoid having to do a dump and fill shortly after putting fresh fluid in after rebuild.
Old Feb 2, 2021 | 03:45 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Oh one other tip I can share.
Take pics before disassembly and each piece you take off. It's so easy to get a gear up side down or a thrust washer etc. If you take a good picture of each gear before and just after removal for orientation, it should make it easier to put it back together properly.
Old Feb 3, 2021 | 04:26 AM
DaX's Avatar
DaX
Loved
Community Favorite
Inside the case will be clean - just wipe out with a rag.
The bellhousing will be nasty. Clean the bulk of the sludge and grime off with rags, water, etc. I use a small brush (toothbrush size, but with stiffer bristles...they're cheap on Amazon) and LA's Totally Awesome Carpet Cleaner from Dollar Tree (it's $0.99 a bottle and it's a great degreaser/cleaner). Brake parts cleaner works well, but it evaporates too quickly so you'll end up going through a ton of it.
For chalky areas on the outside of the case, a media blast is best, but if you don't have access to that, a wire wheel on a drill works wonders, but it's difficult to get in some of the tighter areas with it.
EG-SIXV-TEC
Jan 19, 2010 01:10 PM
Hanmin
Transmission & Drivetrain
Dec 26, 2008 11:44 AM
Flexmyrex
Apr 24, 2007 11:36 AM
fliplyricist1
Feb 28, 2004 10:34 PM
sporkcrx
Oct 9, 2002 07:32 AM
