Jackhammer sound on idle.
Hey everyone! Thank you for letting me join the forum. I recently swapped a JDM D16 for a JDM B18C, Type R motor and LSD tranny, into my 89 Honda Civic Si Hatch. It was a pandemic home garage project... and my buddy and I successfully got it done. So, I took my Civic for a joyride today and when I got home, I hear this mini jackhammer sound coming from the engine compartment. It appears to be coming from the motor. You guys got any ideas? I appreciate it. Please let me know if you have any questions. I tried uploading a short clip but it won't accept it (.mov file). Thank you all.
Motor has oil. I’ll check the oil pump which I believe we replaced during the swap. About the bearing, where would that be located? Thank you for your response.
Wait till the morning and preform a valve lash adjustment, If you rebuilt the engine in any way and did NOT set the valve lash to spec than more than likely your valves are tight or loose
The valve lash adjustment is very easy and the Haynes manual has a step by step procedure with pics. Check the lash and set to spec and start the engine!
MrEG6er21
14
Mar 24, 2004 10:33 PM
