Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
04 Civic Ex 1.7l barely moves in drive
Old Jan 29, 2021 | 07:31 PM
Gaffeth's Avatar
Default 04 Civic Ex 1.7l barely moves in drive
  • No transmission code
  • No engine code
  • Swapped transmission with same result
  • Swapped torque converter with transmission
  • Changed shift solenoids
  • Swapped ecu
  • Checked fluids
Changed wiring harness As well.
I have been trying to figure this one for a month now. Engine starts and runs great, but when in drive, the car doesn't start to move until about 2k rpms. I can put it in d2 and it'll move without issues. I can shift from d2 to 3 and still good. When I go to drive the issue starts. Rpms go up but there's little pull. This led me to swapping the transmission and still getting the same results.
I swapped the shift solenoids, then the ecu, then the engine harness. Fluids were the first thing I checked before all the major swapping. If anyone has any insight into this, or suggestions to try for something I may have overlooked, it would be appreciated.
Old May 6, 2022 | 06:38 PM
Scottmorehead's Avatar
Default Re: 04 Civic Ex 1.7l barely moves in drive
What did it turn out to be? I have a 2005 and barely moves first thing then once it warms up won't move at all.
thanks
Old May 9, 2022 | 05:34 AM
NDNV's Avatar
Internal ATF filter is clogged with clutch debris and restricts flow in the transmission to shift the gears?
nkuser
Nov 20, 2020 08:36 PM
Mikedawg8898
Feb 26, 2016 01:29 PM
jmanuel
Jan 28, 2015 08:58 PM
natedawg173
Honda CR-V & Element
Dec 16, 2014 09:40 AM
MechSteve
Jul 5, 2011 11:58 AM
