2002 Accord Crank no start
Old Jan 29, 2021 | 04:58 AM
anthony13332's Avatar
Icon5 2002 Accord Crank no start
It all started when my radiator blew up from the top seals while on a freeway. as I slowed down to pull over the engine died and would not start back up. about 2 weeks later I replace the radiator and go through the bleeding process as the car started just fine. Thermostat would not open, fans would not kick on but vehicle was not over heating. we got bored after about 20 minutes of waiting and sat in the car and my friend barely even touched the gas which caused the engine to die. Car would not start since then. I've tried replacing the distributor cap and rotor along with new NGK plugs and wires. I tried an entirely new distributor. and to no avail. Took alternator in just to double check and it was fine. battery is pooped but had it plugged into my explorer which should give it enough juice to start up. Gas tank is full. Fuel pump engages. I know its not fuel issue because I sprayed starting fluid into the throttle body with open throttle. replaced the air filter so air should be fine. The only thing I found after hours of research was either some sort of neutral safety switch or crank position sensor. I'm completely out of ideas.
Also might add the only codes popping up are for O2 sensors
Thank you to anyone willing to try and help diagnose what is going on.
P.S. I'm new to diagnosing and working on cars all together. Figured this accord was the perfect stepping stone to getting into vehicle repair.
Old Jan 29, 2021 | 02:08 PM
99stockcivic's Avatar
Default Re: 2002 Accord Crank no start
If you have verified voltage to the starter, and it won't crank, I would say it's the starter.
titocinco
Mar 17, 2018 08:47 PM
OHhonda99
Sep 30, 2015 11:09 AM
roberfro
Feb 3, 2013 06:50 PM
sk1330
Nov 4, 2005 05:23 AM
