Brake lights aren’t working!
Old Jan 25, 2021 | 11:55 AM
nick.hatter's Avatar
Default Brake lights aren’t working!
The main brake lights aren’t working but the tail lights are. As well as the 3rd brake light. So far I’ve checked fuses, break switch and that the bulls have power. I feel like I’ve tried everything! What could be the problem
Old Jan 25, 2021 | 02:58 PM
iwannarace's Avatar
Default Re: Brake lights aren’t working!
You said you checked the brake switch, but did you check the thing that activates the brake switch when the pedal is pressed? Common failure on 90's integras and probably civics. I had to superglue a penny on the tab to fix it.
Old Jan 26, 2021 | 12:25 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Also a continuity check from the brake light socket to the brake switch. As well as the ground(s) in the rear the brake lights utilize. You say you check if the bulbs have power but not sure exactly what you did for that thus my continuity comment.
Old Jan 27, 2021 | 06:15 PM
wunfstgsr's Avatar
Loved
Community Favorite
Are you sure its not a dual filament bulb and the brake filament diddnt go out? My civic recently did this, the tail lights come on but when i applied the brakes there was no extra light. It was the bulb like I mentioned.
Old Jan 27, 2021 | 08:26 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Good catch, I misread considerably. Thanks for catching this. It should definitely be a dual filament bulb. It can also be a continuity problem on the brake light wire. They tend to be a 3 wire setup.
Almost everything in Honda is ground activated so I wonder if the brake/tail lights are the same way, switched ground and it has 1 hot wire. I'll have to look at the electrical diagrams before I can say with confidence.
Old Jan 28, 2021 | 02:59 AM
tony_2018's Avatar
Fish Twig
yeah, if your 3rd brakelight is working than the bulb must be wrong.
Old Jan 28, 2021 | 12:01 PM
wunfstgsr's Avatar
Loved
Community Favorite
Yes I would check for continuity next if the new bulb doesn't work! I do believe its a 3 wire setup on the brakes lights but dont take my word for it..
TomCurllyFry
Mar 25, 2013 09:29 PM
1998_4dr_gsr
Aug 25, 2011 09:15 PM
phrenzykEG6
Apr 12, 2010 08:54 AM
musclehead954
Feb 27, 2008 10:28 AM
db8geezer
Aug 5, 2006 02:27 AM
