No interior lights 2001 Honda Accord
Old Jan 23, 2021 | 11:28 AM
BattleBun's Avatar
Default No interior lights 2001 Honda Accord
Car starts and runs, has head lights but no interior lights radio, or dash. Fuses are good, relays are also good. What else could this be? Thanks
Last edited by BattleBun; Jan 23, 2021 at 11:56 AM. Reason: forgot to add make and model
Old Jan 23, 2021 | 11:33 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: No interior lights
What year and model vehicle is this?
Old Jan 23, 2021 | 11:54 AM
BattleBun's Avatar
Sorry its a 2001 Honda Accord
Old Jan 23, 2021 | 12:39 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: No interior lights 2001 Honda Accord
Although you mentioned fuses are good. Just to make sure you're aware, there are two interior fuse boxes (drivers side and passenger side).
If you haven't checked the passenger side fuses, then check Fuse No. 10 and 9 on that side.
Driver's side would be Fuse No. 8 to check.
If the above fuses are okay, no dash lights could also be caused by a blown driver's side multiplex control unit. See this video to test or fix without replacing the driver's multiplex control unit (MCU). You will lose the dimmer function if you use this youtube fix. -- If is the MCU, you could find a used replacement too.
Old Jan 23, 2021 | 12:43 PM
BattleBun's Avatar
Hey thank you I figured it out! The 40 amp under the hood got moved by a friend and they didn't realize they put it in the wrong place 🤦🏽‍♀️
Old Jan 23, 2021 | 12:44 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Glad you figured it out.
Danigirll
Nov 18, 2017 07:14 PM
BSmoov83
Oct 2, 2012 02:38 PM
zreizzles
Sep 27, 2012 12:44 AM
wicked_gk
Sep 18, 2009 12:49 PM
shawn.hayden
May 1, 2006 06:52 AM
