Honda del sol proportioning valve
I have a 1993 honda del sol si . Brake proportioning valve is leaking. Does anyone know where I can get a new one four wheel disc brakes. Do you know anyone who can rebuild the old part. I appreciate any help.
I've never heard of these being rebuilt. Where in the valve is it leaking, the middle or one or more of the hoses?
If you need a new one, I'd try the stealership first even though it may be costly. Being 4 way disc you may have a hard time finding the right one in the salvage yards. Not sure which prop valve was used on the Si Del Sol's. If you can learn which prop valve it is, you might be able to figure out what other vehicles used the same valve.
Ouch, looking, it was only used on the Del Sol 93-97 Si and it's a discontinued part. I checked on Acura to find it wasn't used in any of their vehicles either. That's going to be a tough one. I see a used one on ebay for just under 100 bucks. Del Sol Si prop valve for disc brakes.
Hey did you find the right one?? before a lot of years my proportioning valve was replaced. At the time the repair shop said numbers mean nothing on those! they installed one labeled 30/30.My crx del sol is a Genuine JDM with front and rear discs with no abs. That proportioning valve is leaking again and i need to install the correct one for my Car! i read on older threads here that a 30/30 is for disc front and drum on the back and that the correct one is a 30/40.but strangely i can find new proportioning valves on ebay claiming that they are for the del sol with rear disc brakes and no abs but they are labeled 30/30.Can anyone please help me on that? maybe someone that has the same car?? Thank you!
DRKSol
Jun 4, 2007 07:51 AM
snowboarderguy44
Nov 14, 2003 09:23 AM
