EF8 front lower control arms and sway bar swap
Old Jan 22, 2021 | 09:29 AM
Jimmy Venditti's Avatar
Default EF8 front lower control arms and sway bar swap
Hello folks I imported my EF8 SiR from Japan a year ago. I want to swap out the lower control arms and sway bar to something more readily available in the US. I went to replace it with standard USDM CRX parts but the control arms do not match up with the radius rod bolt spacing. Its literally millimeters off. Does anybody have a solution without taking the radius arms off or know if something out from a different model will fit. Thank you
Old Jan 22, 2021 | 10:25 AM
Tyson's Avatar
Default Re: EF8 front lower control arms and sway bar swap
EF SiR is pretty unique in front end components. i dont think theres a USDM equivalent. perhaps an accord/prelude might.. but i highly doubt it.
best bet is to buy junkyard JDM parts.
Old Feb 3, 2021 | 06:58 AM
jason_hann53's Avatar
I had this issue when I ordered an ESP traction bar. The center to center holes on the JDM SiR is 2" and the USDM is 1 7/8". If you need a set of front sway bar end links I have a set that is still in great condition. I also have a set of barely used outer tie rod ends for the JDM PS rack
Old Feb 3, 2021 | 09:28 AM
spcrxracer's Avatar
The 1990-1993 Integra components are the same as the JDM CRX SiR
Srispice
Mar 19, 2015 12:53 PM
dc2leftovers
Jul 24, 2009 12:27 PM
luciffer
14
Apr 8, 2009 05:34 PM
baboonstyle
Suspension & Brakes
Nov 12, 2007 05:02 PM
PhoBichNga
Feb 11, 2002 08:15 PM
