An Exhaust temp gauge tells you.....
Old Nov 16, 2002 | 01:20 PM
greebler's Avatar
Default An Exhaust temp gauge tells you.....
It is important because? It lets you know that your engine is getting hot and is about to blow? Because the first sighn of an engine over heating is through the exhaust???
Anyone know?
Old Nov 16, 2002 | 01:22 PM
Kamin's Avatar
Default Re: An Exhaust temp gauge tells you..... (greebler)
its important for turbo'd engines. not for NA.
Old Nov 16, 2002 | 01:49 PM
Eee Pee's Avatar
Default Re: An Exhaust temp gauge tells you..... (KAMiN)
Well, a good temp gauge would allow one to adjust air fuel mixture on a NA motor also....
Old Nov 16, 2002 | 02:32 PM
greebler's Avatar
Default Re: An Exhaust temp gauge tells you..... (E Prep)
Explain.........
what kind of temp guage are you refering to??
Old Nov 16, 2002 | 02:47 PM
Eee Pee's Avatar
Higher temps= leaner fuel mixture
Lower temps= richer fuel mixture
As for the target temperatures, sorry I
just cannot remember right now.
If I recall them I'll add more info.
From what I understand, the Autometer and such,
the ones under $150 just aren't accurate enough.
I'll go look around for more info.
Old Nov 16, 2002 | 02:53 PM
greebler's Avatar
i see
so would you use a air\fuel guage too or just teh exu. temp?
[Modified by greebler, 5:54 PM 11/16/2002]
Old Nov 16, 2002 | 04:43 PM
redcxhatch's Avatar
both, but wide band O2 works best.
Old Nov 17, 2002 | 02:02 AM
D16Z6racing's Avatar
Default Re: An Exhaust temp gauge tells you..... (redcxhatch)
I'm running a GReddy ETG with my boost set up and an APEXi Auto/Turbo Timer. The APEXi timer is nicer IMO, cause it also gives yyour air/fuel ratio.
campbuds
Nov 27, 2004 03:59 PM
ntegls
May 3, 2003 10:02 PM
b16ahybrid
Apr 17, 2003 09:19 AM
civicwagonman
Nov 17, 2002 09:47 PM
Ri5e
Jun 17, 2002 08:50 AM
